Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Saturn
SL1
Drivetrain
Transmission
Replace/Remove
2002 Saturn SL1 transmission removal
2002 SATURN SL1
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
TERRILUSH
MEMBER
1 POST
how do you get the transmission out easily?
Mar 21, 2009 at 8:44 AM
BELALZ
MEMBER
Drop the subframe to the get the transmission out the wheel well. 4x18mm bolts.Tranny itself is held by 4 15mm bolts. Also 3 small bolts on the flywheel cover. Disconnect the shifter cables and PULL.
Apr 18, 2009 at 7:12 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
