Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
BELALZ
MEMBER
Drop the subframe to the get the transmission out the wheel well. 4x18mm bolts.Tranny itself is held by 4 15mm bolts. Also 3 small bolts on the flywheel cover. Disconnect the shifter cables and PULL.
