2002 Saturn SL1 Racing motor
2002 SATURN SL1
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIMMYREEDY
Had a dirty throttle body, cleaned it out before put it back togeather ran fine. This time after putting it back togeather the motor is racing at around 2500 rpms and won't idle back down. Any suggestions?
Nov 8, 2009 at 1:31 AM
SATURNTECH9
  • 30,869 POSTS
So do have a sl1 4cyl u put v6 that would make it a vue or ls that yr with a v6.if it is a sl1 4cyl then I would put the air intake on start it up take some carb spray and spray around the gasket of throttle body and all those hard plastic lines on throttle body and don't forget rubber grouments that are under the lines look for a rpm change when spraying.most likely u have a vaccuum leak somewhere also check and make sure have everything plugged in wires etc.u can also check that hose the runs from ur valve cover to intake the short s shaped one.that's a good start for now let me know what u find.also donations and feedbacks are greatly appreachiated.
Louie
Nov 8, 2009 at 4:13 AM
