2002 Saturn SL1 Jumps into reverse
13,200 MILES • 4 CYL • FWD • AUTOMATIC
JAY58SEA
Car jumps into reverse when trying to back up--when in drive, car is just fine; no problems whatsoever-no hesitation, slippage or anything; what could be the problem?
Jan 20, 2010 at 11:53 AM
SATURNTECH9
  • 30,869 POSTS
Unfornately there's no easy answer to ur question u could have low line pressure in ur transmission a bad 2nd gear piston seal leaking a bad reverse servo piston seal or a loose input shaft nut.without testing the transmission and seeing it it's impossible to tell.for ur yr and model though I would suspect the most likely cause for the delayed reverse would be a loose input shaft nut.ur best bet would be to have a professionial look at.let me know what u find.
Jan 21, 2010 at 4:28 AM
