2002 Saturn SL1 DIAGRAMS
90,000 MILES • 4 CYL • FWD • AUTOMATIC
BAMACHAMPMR
I am getting ready to flush and fill my radiator.
can you send me a diagram the Saturn SL1 2002 cooling system with identifying marks.Also a diagram where the thermostat is?
thanks
Oct 6, 2009 at 6:46 AM
SATURNTECH9
  • 30,869 POSTS
To find the thermostate follow the lower radiator hose to the engine block that's ur thermostate housing two 10mm bolts hold it on if ur changing it I recomend the factory one it comes with a new oring and the tool to remove it and install it.the block drain is right below the housing it's a 10mm bolt with a washer don't loose the washer it's the seal for it.on the passengers side of the radiator on the bottom is the radiator drain.u need anymore info let me know.
Louie
Oct 6, 2009 at 5:39 PM
