2002 Saturn SL1 coolant temp sensor
103,845 MILES • 4 CYL • FWD • AUTOMATIC
MOKEYBOZO
  • 6 POSTS
can anybody give me a diagram of where the coolant temp sensor is located? I was told in the head below the upper radiator hose but the one I found and replaced was in the air intake behind the driverside headlight.
Mar 8, 2010 at 9:23 AM
  • 75,988 POSTS
SOHC or DOHC engine??
Mar 8, 2010 at 9:48 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank u so much for ur donation it really helps us answer everyones question.u replaced the inlet air temp sensor.the coolant temp sensor is screwed into the cyclinder engine below where the upper hose goes almost where the head meets the engine block on the right side of the head facing the engine.there are two wires going to it a yellow one and a black one.the sensor looks just like the one u change even has the same style connector.don't forget to check and make sure the connector isn't corroded.let me know how it goes.
Mar 8, 2010 at 9:51 AM
  • 75,988 POSTS
DOHC is at the rear of the cylinder head, near upper radiator hose SOHC on rear of cylinder head near upper radiator hose DOHC
https://images.2carpros.com/forum/automotive_pictures/12900_dohc_1.jpg
SOHC
https://images.2carpros.com/forum/automotive_pictures/12900_sohc_1.jpg
Mar 8, 2010 at 9:55 AM
