2002 Saturn SL1 cant find owners manual have light on
42,000 MILES • 4 CYL • 2WD • AUTOMATIC
BABETTE
Hi! I have a light that is a square with a squiggly line in the middle and an arrow pointing down above it. I need to know what that means so I can fix whatever is causing it. Can you help? Thanks so much!!!
Babette
Nov 27, 2009 at 11:44 PM
SATURNTECH9
  • 30,869 POSTS
can u send a pic of it also check ur coolant level when its cold should be up to the bottom of the seam where the two pieces come together.
louie
Nov 28, 2009 at 2:32 AM
