2001 Saturn SL1 Won't go into gear while cold
2001 SATURN SL1
86,000 MILES • 4 CYL • FWD • AUTOMATIC
1938M20
While car is cold after being in reverse, car will not go into drive. Lever is in drive and car will not move. After 1-2 minutes it will work.
Jan 28, 2010 at 10:53 AM
SATURNTECH9
  • 30,869 POSTS
do u have any codes in the transmission?most likely u have ethier a low line pressure in the transmission.or u could have a gear piston bleeding down.also possible a loose input shaft nut common on those later models.it will have to be checked out by someone that knows saturn transmissions.there easy to work on but for some reason alot of people just cant figure them out.even at the big chain transmission shops.let me know what u find.
Jan 29, 2010 at 6:09 AM
