Transmission problem
2001 Saturn SL1 4 cyl Two Wheel Drive Manual
I have a 2001 Saturn SL1 that I just replaced the 2 shift cables and now the transmission will not shift into any gear. The gearshift will move side to side and the cable on the transmission will move the selector lever on the transmission, but I cannot put the transmission in any gear. the Haynes Manual says something about a solenoid, (it is a 5Speed Transmission) but gives basically no information - I drove it up on ramps in 1st gear before I started - got the cables replaced and now it won't shift into any gear at all, not even if I disconnect the cables at the transmission and try it by hand. Any ideas?
Jul 3, 2010 at 6:48 AM
