2001 Saturn SL1 Transmission repair costs/suggestions
2001 SATURN SL1
88,000 MILES • 4 CYL • FWD • AUTOMATIC
SATOWNER
My car has recently been developing a few problems that I think are transmission issues.
1. About 50% of the time, when I shift into reverse, the car pauses, then slams into gear.
2. Especially in the lower gears, I get a humming or light buzzing sound (as if something is spinning very fast.) The "speed" of the hum changes as I switch gears.
3. The car seems to stay in the lower gears longer now. This is most noticeable when I have just started driving the car (before it warms up) and when I am going up hills.
Am I correct that this is a transmission issue? Is it likely that I will need to get a new transmission? What is the cost of this likely to be?
Sep 20, 2010 at 5:41 AM
BILLYMAC
  • 2,204 POSTS
Hi Yes you are right these are trans issues.i would have trans scanned and tested by a trans shop.
this will tell you how severe the damage is and if caught in time may be the diff in a repair or a new trans.
if it needs rebuilt you are looking at min 1400. if it goes on and breaks something and you have to get a whole new trans ..maybe 3000. so it is best to find out now before the real damage get's here
Sep 21, 2010 at 1:24 PM
