2001 Saturn SL1
149,000 MILES • 4 CYL • FWD • AUTOMATIC
LMH102076
i think my ignition swich is messed up because i put my key into the ignition and turned it and the dash lights came on and the gages worked but when i tried t start it it wouldnt do anything
Sep 15, 2010 at 5:16 AM
SATURNTECH9
  • 30,868 POSTS
I doubt it's the switch they hardly ever go bad most likely it's your starter.The first thing you need to do is check and make sure the battery cable's are clean and tight then make sure your battery test's good.Do you have a multimeter?That way we can trace the problem down.
Sep 15, 2010 at 5:24 AM
