2000 Saturn SL1 transmission
BAYSATURN
Transmission problem
2000 Saturn SL1 4 cyl Two Wheel Drive Automatic
I have code po714 showing up and service engine light is on, what do I replace the sensor, the fluid et..
Mar 26, 2010 at 8:24 AM
SATURNTECH9
  • 30,869 POSTS
U wernt towing anything with ur car were u?if u don't have acess to a scanner that can read trans temp on ur car u can start with changing ur sensor if u change ur sensor make sure u get a brass tipped one not a plastic tipped one there under 20.check the connector too.let me know what u find.
Mar 26, 2010 at 9:05 AM
