2000 Saturn SL1 REVERSE
198,000 MILES • 4 CYL • FWD • AUTOMATIC
ORTIVIZ08
WHY DOES MY CAR KICK WHEN IT IS IN REVERSE?
Sep 18, 2010 at 11:34 PM
SATURNTECH9
  • 30,868 POSTS
Do you mean you have a delay and a bang into reverse?Also go to auto part's store like auto zone and have them scan your car for code's and let me know what the number's are if you have any.Also any trouble in any of your forward gear's?
Sep 19, 2010 at 3:33 AM
ORTIVIZ08
YES, IT DELAYS AND BANGS WHEN I PUT IT IN REVERSE AND IT CONTINUES BANGING WHILE I AM REVERSING.
Sep 20, 2010 at 5:33 PM
SATURNTECH9
  • 30,868 POSTS
I would remove the transmission side cover and inspect the input shaft nut and see if it was loose real common for that year and model to loosen up.Then i would check the min and max pressure when it was hot then i would remove the valve body and air check the clutches and make sure there all holding.Do you have any code's?
Sep 21, 2010 at 6:36 AM
