2000 Saturn SL1 NO tail lights or brake lights,backup light
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
CUBS321
What and where do i check to fix this problem. I looked at the booklet about fuses under hood or under dash didnt see anything that said tail lights or brake lights. Thank you.
It was the fuse and one blown out light. thank you.
Oct 14, 2009 at 3:22 AM
SATURNTECH9
  • 30,869 POSTS
if u go in the under hood fuse box theres a fuse marked brake light check and see if the fuse is good and has power.let me know what u find.
louie
Oct 14, 2009 at 3:55 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_underhood_brake_fuse_1.jpg
The brake fuse is in the underhood fuse box, sorry if the picture isn't readable. I did magnify it. Not only check the fuse, use a testlite, see if fuse circuit is hot. A place to start.
Oct 14, 2009 at 4:05 AM
SATURNTECH9
  • 30,869 POSTS
thanks for the pic jdl123 that will help them find the fuse better.
louie
Oct 14, 2009 at 8:22 AM
JDL
  • 16,098 POSTS
hey, saturntech9, I didn't see your post before I posted. I try to answer only unanswered posts. Sometimes two or three of us are looking at the same post. Have a good day.
Oct 15, 2009 at 1:51 AM
SATURNTECH9
  • 30,869 POSTS
thats ok it happens no biggie.
louie
Oct 15, 2009 at 4:21 AM
