Brake warning light on?
2000 SATURN SL1
STAMPTABULOUS
Yesterday, when I turned on my car, the brake warning light and then the service light came on. What does that mean?
Oct 1, 2009 at 1:32 AM
SATURNTECH9
  • 30,869 POSTS
that usually means your brake fluid is low in your master cylinder. check to see if it is low. if it is you either have a leak or your brakes are worn out. most likely your brakes just need to be replaced. check the fluid and let me know how it goes.
Louie
Oct 2, 2009 at 12:10 PM
IRILACNEK
Have same problem with 2001 SC2. It was low brake fluid in master
Dec 12, 2020 at 1:10 AM
  • 55,224 POSTS
yep, usually because of he front brake pads being low. here is a video to help you do the front brakes:
https://youtu.be/-uuJsxJ6V8k
Dec 13, 2020 at 5:03 AM
