Blinking Security Light- Wont Start
74,000 MILES • 4 CYL • 2WD • AUTOMATIC
MWMSATURN
Sometimes the engine wont start when I turn the key.... when this happens the security light is blinking. Wait a few minutes and it fires right up?
Jun 24, 2009 at 8:38 AM
TIFFANY034
I have a 2001 Saturn SL1. The answer to that question is simple. How old is your battery? The battery has to have enough life or juice to start your car and run the car's computer at the same time. When it is getting weak, on this particular brand of car, it is not able to maintain enough power to fully power the car's computer, so the computer goes crazy sending that security light blinking on your dash to confuse you. And that is exactly why it's doing it, because it is confused itself. So with that said, before it leaves you stranded, like mine did out of town where you know no one, replace your battery or at least have your charging system checked. Here is some good advise!! The battery will probably test GOOD or even NOT BAD, but if you replace it anyway it will save you months worth of headaches. Trust me I have been through it 3 times until I took control of the situation, stopped listening to the auto parts people who were testing it and it said it was checking good, and replaced it any way!
Jul 4, 2009 at 12:53 AM
PUZZLED56
My Saturn had the same problem... my mechanic had to fix the little wires from where the key goes for the security system.... hasn't happened since
Oct 3, 2018 at 11:16 AM
