Is it posibly to change out just the bell housing and the bearing behind it from or transmission to another or would you have to change it all because one of the bearings behind the two seals got loose and cut up into the bellhousing and I was wondering if I would be able to just switch the bellhousing and the seal behind the bell housing out. And how many different types of trannys did they make for a 1999 Saturn sl1 because we got the new tranny in my car now and it drive great in 1st gear but it will not upshift
Wednesday, July 7th, 2010 AT 1:56 AM
