How much would it cost to either rebuild the transmission, or put in a new transmission, on a 99 Saturn SL1?
Aug 19, 2010 at 7:54 AM
SATURNTECH9
✓Experienced Mechanic
First of all thank you so much for your donation.I have only had to rebuild a handful of transmission's on the saturn S model.There really good transmission's so let's start with what problem your having with your transmission.Then i can tell you the best way to repair it.
Aug 19, 2010 at 8:15 AM
DLMNF4
MEMBER
It shifts roughly between 1st and second gear, and it slips in and out of third gear
Aug 19, 2010 at 8:20 AM
SATURNTECH9
So you have a hard shift between first and second?It also slip's in and out of third?When you say it slip's in and out of third doe's it shift to a lower gear?Or does it just freewheel?Also do you have any code's?If you don't know could you please go to a auto part's store and see what code's you have and let me know what the number's are.
