1999 Saturn SL1 Starting my Saturn
1999 SATURN SL1
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
COLLEENANNE07
I have moved from Michigan to South Carolina and this is my first summer with such hih temperatures - not sure if that's part of the problem. I was having trouble with my car starting a few weeks ago - I would drive somewhere, run inside and come back out and my car would not start. If I waited about 30 mintues, It would start. Sometimes if I hit on the starter it would start right away, other times I had to wait the full 30 mintues. Anyway, I had my starter replaced and it's been starting fine until today. I ran inside the store and when I came out, my car would not start. It was different this time though. Before, when I turned the key, battery power came on, the radio came on, etc. This time when I turn the key it fades in & out, the RPM revs up and down and shakes. When I turn the key completely over to start the car, all I get is a quiet, high-pitched beeping/squeal. I have no idea what is going on with my car and since I've recently moved, I don't know who to take my car to without paying an arm & a leg. Any help is much appreciated!
Jun 24, 2010 at 6:33 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Do you have a multimeter?So we can see how many volt's your battery has etc.Also make sure your battery cable's are clean and tight.
Jun 24, 2010 at 7:04 AM
COLLEENANNE07
I'm not sure what a multimeter is. I could have my husband jump the battery tonight - it's just it usually is completely dead so I didn't think it was the battery. Cables are tight and clean.
Jun 24, 2010 at 7:08 AM
SATURNTECH9
  • 30,869 POSTS
A multimeter is a meter that measure's volt's ohm's etc ask your husband he might even have one.If the battery is completely dead then i would take it out and have it charged and tested at a auto part's store like auto zone.Also make sure the battery cable's are clean and tight very important.
Jun 24, 2010 at 7:55 AM
