1999 Saturn SL1 SPEED SENSOR
1999 SATURN SL1
19,800 MILES • 4 CYL • 2WD • MANUAL
MIHONIE
WHERE IS THE SPEED SENSOR IN THIS CAR. I AM GUESSING THE MODEL OF CAR BUT MY SPEEDOMETER ISN'T ACTING RIGHT . THINK IT MIGHT BE THAT OR CABLE. COULD IT BE ANYTHING ELSE?
Oct 29, 2010 at 8:27 PM
SATURNTECH9
  • CAR REPAIR CONTRIBUTOR
  • 30,869 POSTS
The speed sensor on the car you listed is right by where the axle come's out of the transmission.They hardly ever go bad.That car doesn't have a speedometer cable.So what kind's of problem's are you having with the car?Also any code's?Look on your registration card for the proper year make and model that would really help to have the correct info of what kind of car your having problem's with.
Oct 29, 2010 at 8:30 PM
MIHONIE
The speedometor is wrong. I was in a front end collision could this be the cause?
Oct 29, 2010 at 10:03 PM
SATURNTECH9
  • 30,869 POSTS
A front end wreck isn't going to make the speed sensor go bad or read te incorrect speed.
Oct 30, 2010 at 12:28 AM
