1999 Saturn SL1 Screeching A/C & clicking blower
SARAHNIK
Air Conditioning problem
1999 Saturn SL1 4 cyl Automatic 76,000 miles
I would like to know what to ask the mechanic to fix:
1) thru winter, blower would click but work
2) A/C not very cold
3) in past week, pressing the A/C button makes a screeching noise
Is the screeching from a belt possibly?
Could I use freon to cool down the temp?
Recently (past 6 months) had starter and belt replaced.
I want to make sure I know what I'm asking for so I don't get ripped off and wondering if this sounds minimal or highly problematic.
Thank you,
Sarah Nicole
PS 11 year old car but only 76,000 miles
Apr 11, 2010 at 9:46 AM
SATURNTECH9
  • 30,869 POSTS
[quote:37dd50cce1="SarahNik"]Air Conditioning problem
problematic.
Ur a/c not very cold might just need a recharge or u could have a leak hard to say without seeing it.usually they will look for visable leaks when they charge it.have them put leak dye in it if they just charge just in case there's a leak.on ur squeling with the a/c on u probably just have a Weak belt tensioner letting the belt slip.as far as ur inside blower fan inop that's hard to say without doing some tests to see what's going on there.let me know if u have anymore questions.
Thank you,
Sarah Nicole
PS 11 year old car but only 76,000 miles[/quote:37dd50cce1]
Apr 11, 2010 at 10:15 AM
SARAHNIK
THANK YOU!
I've never recharged my A/C as far as I know so I will have mechanic do so asap!
Just wondering how much recharging usually costs?
Thanks again.
Apr 11, 2010 at 11:41 AM
SATURNTECH9
  • 30,869 POSTS
The labor is 1.5 hrs times 80-100 per hr depending on shop labor rate.the r134 is may 50.let me know if I can help u any further.
Apr 11, 2010 at 12:51 PM
