1999 Saturn SL1 Overheating without loss of coolant?
165,000 MILES • 4 CYL • 2WD • MANUAL
BLUSATURN1
A couple weeks ago: coolant leaking badly & over heating (dial all the way over in red). So I take it in. They check the cooling system & said the water pump was leaking. Recommended new water pump & thermostat to remedy problem. Done. Car is still over heating after 5 minutes of driving, even with coolant full. Consequently, the heater is also not working, only blowing out cold air. =(
*There was a about a week's time that lapsed between the diagnoses and actually getting the repairs, during which he said driving it around may have made a bigger problem than before. What could be wrong that's making it overheat? Any response is greatly appreciated.
Feb 17, 2009 at 10:55 AM
  • 75,988 POSTS
No leaks
Could be the thermostat again, clogged-up radiator/cap and water pump.
Get it block and pressure tested to find out more why.
Feb 17, 2009 at 11:12 AM
