1999 Saturn SL1 Jerking when put in reverse
153,000 MILES • 4 CYL • 2WD • AUTOMATIC
LBRANDON
I just purchased a Saturn SL1 and the car seems to jerk when putting it in reverse what could be wrong.
Sep 20, 2010 at 10:11 AM
SATURNTECH9
  • 30,869 POSTS
Most likely you need a valve body and you possibly have a loose input shaft nut.But without some test's checking the transmission fluid pressure and air checking the clutches also check for code's.To figure out what you need or you have bigger problem's.
Sep 20, 2010 at 10:43 AM
