1999 Saturn SL1 headlights
171,000 MILES • 4 CYL • FWD • MANUAL
STKRISMAN
The car was in a collision, and the frame in the front end was bent, and the lights were smashed up, anyway we repaired the front end, with new lights, and the hazards and turn signals work, as well as the passenger headlights when they are turned on. the running lights dont turn on automatically anymore, and the driver side headlights will not work as well.. Fuses are all fine, where else could the problem be?
Mar 17, 2010 at 3:16 PM
SATURNTECH9
  • 30,869 POSTS
[quote:25dcec0f6d="Stkrisman"]Electrical problem
1999 Saturn SL1 4 cyl Front Wheel Drive Manual 171000 miles
The car was in a collision, and the frame in the front end was bent, and the lights were smashed up, anyway we repaired the front end, with new lights, and the hazards and turn signals work, as well as the passenger headlights when they are turned on. the running lights dont turn on automatically anymore, and the driver side headlights will not work as well.. Fuses are all fine, where else could the problem be?[/quote:25dcec0f6d]U said the running lights don't work does the high beam work on the passenger side?alot of the time in front end wrecks the wires on the bottom of the underhood junction box get cut there.also I would follow the wires from the under junction box along the whole foward lamp harness that's a seperate harness from the engine harness that goes to the lights and all the wires are bundled together then branch out where the connectors look for cut wires and cut tape.let me know what u find.
Mar 18, 2010 at 6:25 AM
