1999 Saturn SL1 fair automotive repair estimate
1999 SATURN SL1
138,000 MILES • 4 CYL • 2WD • AUTOMATIC
GREENCHEVYMALIBU
  • 230 POSTS
Just wanted to know if you could possibly give me a fair estimate on replacing left and right wheel cylinders and a neutral safety switch. thanks
Jan 29, 2010 at 12:30 AM
SATURNTECH9
  • 30,869 POSTS
[quote:897f78c710="greenchevymalibu"]1999 Saturn SL1 4 cyl Two Wheel Drive Automatic 138000 miles
Just wanted to know if you could possibly give me a fair estimate on replacing left and right wheel cylinders and a neutral safety switch. thanks[/quote:897f78c710]
first off thank u so much for ur donation it really helps to keep this website helping people with there car questions.ok lets start with ur wheel cyclinders.labor is 3.4hrs times what ever there shop rate is average is 80-100 per hr.the parts themselves are factory ones are about 80 and aftermarket can be as little as 25 but u dont want to go to cheap on them.ur neutral safety switch labor is .6hrs times 80-100 per hr depending on how much they charge per hr.the part is for a factory one about 50 if u shop around aftermarket maybe u can find it cheaper.also thank u for using 2carpros it was a pleasure helping.
Jan 29, 2010 at 6:29 AM
