1999 Saturn SL1 battery and oil light flash only when start
JOAN J.
Engine Mechanical problem
1999 Saturn SL1 4 cyl Front Wheel Drive 31000 miles
Had the battery , alternator and oil changed, mechanic says no problems, but when starting in the am only below 20 degrees, battery and oil light will flash for 30 seconds, car starts fine. What's the problem?
Feb 10, 2009 at 8:29 AM
  • 75,988 POSTS
Check the alternator belt tension and the oil pressure
Feb 10, 2009 at 8:32 AM
