1999 Saturn SL1 A/C Compressor
1999 SATURN SL1
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
KAYLAMCRAD
A/C Compressor disengauging, AC Clutch Making sqeeking noise appears to be rusted. AC Clutch kicks on and off. Can the clutch be replaced without replacing the compressor??? Oil clutch still kicks on and off but not sqeeking as bad.
Sep 14, 2009 at 11:45 AM
Noise from the compressor usually means the compressor is on its way out. But noise can also be caused by cross-contaminated refrigerant (operating pressure too high), air in the system or the wrong type of compressor lubricant.
Sep 14, 2009 at 12:03 PM
