1999 Saturn SL1
16,000 MILES • 4 CYL • 2WD • MANUAL
JUCKEM4
My 1999 manual Saturn won't come out of gear. It starts with the clutch in but even if the shifter is in neutral when you let the clutch out it tries to move like it is in gear. I cannot get it out of gear and really have no idea what could cause this. Thanks
Jun 29, 2009 at 1:34 AM
CLOCKWISEMONEY
  • 7 POSTS
Have you checked to see if your shift linkage is still connected/not broken. This would cause the given problem as moving the shifter through the gear cycle would only move the snapped linkage and not the gears in the transmission.
Jun 30, 2009 at 9:41 AM
