1998 Saturn SL1 TIE ROD END
THEHAIRS
Suspension problem
1998 Saturn SL1 4 cyl Front Wheel Drive Manual 200.00 miles
DO YOU HAVE TO REPLACE THE BALL JOINT WHEN YOU REPLACE THE TIE ROD?
Dec 25, 2009 at 11:54 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, If you are replacing the Outer Tie Rod End it comes as one piece. Outer Tie Rod
https://www.2carpros.com/images/question_images/199378/original.jpg
Inner Tie Rod
https://www.2carpros.com/images/question_images/199379/original.jpg
Dec 26, 2009 at 1:07 AM
