1998 Saturn SL1 Starts sometimes
MBWRITER51
Electrical problem
1998 Saturn SL1 Manual
My Saturn starts when it wants to. Will start with a push start. I have a fully charged battery. When the tow truck showed up to take to the shop it started 5 times in a row. Obviously I cancelled the tow. One day later, it started fine, took it around the block. Parked it in the driveway, Now won't start. Anyone heard of a "switch on the clutch pedal?" Could that be the problem, if so is it exspensive to fix? New starter?
Feb 24, 2010 at 11:44 AM
SATURNTECH9
  • 30,869 POSTS
[quote:02504fda3d="mbwriter51"]Electrical problem
My Saturn starts when it wants to. Will start with a push start. I have a fully charged battery. When the tow truck showed up to take to the shop it started 5 times in a row. Obviously I cancelled the tow. One day later, it started fine, took it around the block. Parked it in the driveway, Now won't start. Anyone heard of a "switch on the clutch pedal?" Could that be the problem, if so is it exspensive to fix? New starter?[/quote:02504fda3d]
so does ur engine spin when ur trying to start it?do u have a test light or multimeter?can u hear any noises when trying to start it?
Feb 24, 2010 at 11:55 AM
