1998 Saturn SL1 slavecylender
310,000 MILES • 4 CYL • FWD • MANUAL
JUSTIN830
when i depress the clutch peddle the clutch dose not fully dis engage the clutch,presure plat and throw out baring are all new also the trans was just changed the clutch resivor under the hood is full is there another resivor and also what else could be wrong
Jan 28, 2009 at 1:36 AM
DOCFIXIT
  • 18,828 POSTS
Assume system bleed air very diffucult to get out that would do it. No fluid loss? checked slave for leaks? Try bleeding with tube on bleeder valve placed into container of fluid. Then pump till no bubbles seen.
Jan 28, 2009 at 6:10 AM
