1998 Saturn SL1 Hard shifting
110,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGDADDY_1
Shifting from R to Drive it shifts hard. if you let it pause in neutral for a while.... it is better. Hard enough that it snaps your neck a little.
Aug 7, 2010 at 4:44 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Is there a delay and then a hard shift into reverse?Or just a hard shift into reverse?Also does it shift hard when shifting 1st to 2nd etc.Could you go to a auto part's store like auto zone and see if you have any code's.If you do let me know what the number's are.
Aug 7, 2010 at 4:58 AM
BIGDADDY_1
It normally only sifts hard when you go from Reverse to drive. shifting while driving is fine. I'll try to go to a parts store and check on any codes...it might be a few days before I can get there
thanks
Aug 7, 2010 at 5:15 AM
SATURNTECH9
  • 30,869 POSTS
Alright keep me posted.
Aug 7, 2010 at 5:40 AM
