1998 Saturn SL1 Battery Issues??
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
BEAGLEHUGS
I have just replaced the battery in my vehicle, but it still does not start every time... sometime it starts sometimes it does not... what is wrong with it
Mar 9, 2010 at 12:37 PM
SATURNTECH9
  • 30,868 POSTS
[quote:6a1336995a="beaglehugs"]Electrical problem
1998 Saturn SL1 4 cyl Two Wheel Drive Automatic 170000 miles
I have just replaced the battery in my vehicle, but it still does not start every time... sometime it starts sometimes it does not... what is wrong with it[/quote:6a1336995a]
when u replaced the battery did u have the alternator tested?also when it doesnt start does the engine turn over or not.can u hear the starter click?
Mar 9, 2010 at 12:55 PM
BEAGLEHUGS
I have not tested the altenator yet. and when I turn the key you can hear a low hum put that is it nothing happens
Mar 10, 2010 at 8:05 AM
SATURNTECH9
  • 30,868 POSTS
where is the humming comming from?is that why u repalced the battery because it wasnt starting and humming?make sure the battery cables are clean and tight.do u have a multimeter or test light to do some testing and i could help u fiugure out why its not turning over.let me know.
Mar 10, 2010 at 9:28 AM
BEAGLEHUGS
When I tried to start it up yesterday it did. then i turned off and when I tried again it did not, but I did hear this time the start click
Mar 11, 2010 at 7:14 AM
SATURNTECH9
  • 30,868 POSTS
Sounds like a bad starter when it gets hot it stops working.wel if u have atleast 12 volts all the time to the postive battery cable on the starter and atleast 12volts when u turn the key at the little purple on the starter then u have a bad starter.let me know what u find.
Mar 11, 2010 at 7:46 AM
