1998 Saturn SL1 98 Saturn Check Engine Code PO446
140,000 MILES • 4 CYL • 2WD • MANUAL
RBRASE
  • 20 POSTS
Dear Sirs,
I own a 98 Saturn SL1 and cannot seem to pass an emissions test because of a check engine code of P0466, Evap. Emissions purge solniod (attached to the filler neck at the back of the car). I have replaced the solnoid with a couple out of a junkyard and they do not work. I have power going to the solnoid but do not hear a clicking sound. I will buy a new one and try that. Could it also be the purge canister. If so, where is it located and how do I test it. Could it be anything else?
I asked you this queston last week but can no longer find my posting.
Thank you
Randy Brase
Grand Prairie, TX
Jun 14, 2010 at 2:54 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Would you recheck the code have no info on a P0466
Jun 14, 2010 at 4:08 AM
RBRASE
  • 20 POSTS
Sorry, PO446
Jun 14, 2010 at 4:12 AM
DOCFIXIT
  • 18,828 POSTS
O.K. caused by blockage in a line or canister in engine compartment. Check line to tank and line to Evap canister if flowing free then check canister
Jun 14, 2010 at 4:27 AM
RBRASE
  • 20 POSTS
Thank you. Question, should I still replace evap. emission purge solniod on the gas filler neck? I purchased a new from a Chev/Saturn Dealership at lunch today. If I remmber what you told me, turn the igition to acc (do not start the engine) and unplug and plug the electrical connector to see if the solniod clicks.
Where is the canister in the engine compartment?
Thank you,
Randy Brase
Jun 14, 2010 at 5:56 AM
RBRASE
  • 20 POSTS
By the way, the car runs peferct.
Jun 14, 2010 at 5:59 AM
DOCFIXIT
  • 18,828 POSTS
Charcoal canister looks like black coffee can
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_481.jpg
Jun 14, 2010 at 6:34 AM
RBRASE
  • 20 POSTS
Last question, how can you tell if the Charcoal canister is bad vs Evap Emssion Purge solnoid?
Thank you,
Randy
Jun 14, 2010 at 6:38 AM
DOCFIXIT
  • 18,828 POSTS
If solenoid does not click then it's faulty if power to it is verfiyed. canister will not allow air to pass through
Jun 14, 2010 at 6:58 AM
RBRASE
  • 20 POSTS
Once again, 2Carpros nailed the problem! My Saturn is back on the road!
Thank you,
Randy
Jun 15, 2010 at 5:35 AM
