1997 Saturn SL1 transmission
STORM101
  • 1997 SATURN SL1
Transmission problem
1997 Saturn SL1 4 cyl Front Wheel Drive Manual
my transmission started going into all the gears except 2cd, once I cut if off to inspect it would only go in 1st, reverse and 5th can tou tell me whats wrong
Monday, May 17th, 2010 AT 8:55 PM
SATURNTECH9
  • 30,869 POSTS
It sounds like one of your shifter cables came loose I would check under your hood make sure the cables have there clips attaching it the transmission and the clips attaching the cable ends to the shifter arms. On the inside at the base of the shifter make sure both cables are attached. Let me know what you find.
Monday, May 17th, 2010 AT 10:20 PM
