Good Afternoon,
I am currently working on this car and having an exhausting problem.
I have tested the battery and I have tested the Solenoid and starter. I have connect a voltage meter to every possible place on the car still with no luck.
When I turn the key, the Daytime Driving Lights, Stereo and A/C cut off. There is no turn of the block to even attempt starting.
I removed one of the spark plugs this evening and noticed that it was heavily corroded. Could this cause the engine to not even attempt to turning? The car was running completely fine about 4 days ago.
Thanks,
Brad-
Thanks,
Brad-
Nov 27, 2009 at 11:09 AM
