1997 Saturn SL1 Starting Issues
111,000 MILES • V8 • 2WD • AUTOMATIC
FRENCHHORNFLINT4
Good Afternoon,
I am currently working on this car and having an exhausting problem.
I have tested the battery and I have tested the Solenoid and starter. I have connect a voltage meter to every possible place on the car still with no luck.
When I turn the key, the Daytime Driving Lights, Stereo and A/C cut off. There is no turn of the block to even attempt starting.
I removed one of the spark plugs this evening and noticed that it was heavily corroded. Could this cause the engine to not even attempt to turning? The car was running completely fine about 4 days ago.
Thanks,
Brad-
Nov 27, 2009 at 11:09 AM
  • 75,988 POSTS
Do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 27, 2009 at 12:39 PM
