1997 Saturn SL1 Shifter stiff
100,000 MILES • 4 CYL • 2WD • MANUAL
CHUNKIE777
I brought my car in to get fixed. They fixed the clutch and the master cylinder. The car ran great for about 15 minutes and then went right back to its old ways. It is extremly hard to get it into first or second gear. If i turn the car off it slides into any gear with no problems but when the car is running it is extremly hard to get it into gear. What could this be? I am worried it may be the transmission but after researching this seems to be a common problem with saturns and many people have suggested that it could be the pressure plate, the slave cylinder or the clutch Hydraulics. What do you think it could be?
Mar 12, 2010 at 11:56 PM
SATURNTECH9
  • 30,869 POSTS
As far as the clutch goes did u have the clutch disc,pressure plate throw out bearing and flywheel turned or replaced?also u said u had the clutch master replaced did u just have that replace or did they replace the clutch master and slave cyclinder as a assembley?
Mar 13, 2010 at 3:31 AM
