1997 Saturn SL1 Overheating
MARTIN8401
  • 1997 SATURN SL1
Engine Cooling problem
1997 Saturn SL1 Automatic
When I drive my Saturn with the AC on or I let it idol my car starts to over heat. If I turn my AC off and drive my car then it starts to cool back down.
Sunday, July 26th, 2009 AT 6:21 PM
Are both cooling fans On when AC in use? If so try replacing thermostat and make sure the coolant level is okay
Sunday, July 26th, 2009 AT 7:20 PM
MARTIN8401
No the radiator fan does not turn at all and I wasn't aware that there was another fan. I asked a local parts store if it could possibly be my fan and he asked me if any of the blades were broken if not, suggested replacing the motor for the radiator fan. Could this be the correct step to try first?
Sunday, July 26th, 2009 AT 11:56 PM
Wrong, what happens if you replace the motor and it doesn't come on? Power the fan motor from the battery and tell me what happened. If it comes on could be the fan relay or the engne temperature gauge sending unit.
Monday, July 27th, 2009 AT 12:28 AM
