1997 Saturn SL1 fuel system
168,000 MILES • 4 CYL • FWD • MANUAL
STUPIDSATURN
hi, i have this saturn it is having problems starting it is turning over and acts like it wants to start there isn't any fuel getting to the spark plugs. when we checked to see if the fuel pump was working by disconnecting the line from the pump to the filter and cranking the engine.. we did and it didnt have any fuel coming out. we then switched the fuel pump and tank since it is an integral pump. The problem still remains. i did switch the relays and nothing happend. HELP!!!
Apr 28, 2010 at 3:16 PM
BLUELIGHTNIN6
  • 16,542 POSTS
need to check for power getting to the pump. if no power then check fuse and wiring.
Apr 28, 2010 at 5:01 PM
