1997 Saturn SL1 car keeps bucking up hills
220,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHOALIN08
I have a 1997 saturn sl1. It has 220000 miles on it. Recently it has started to buck going up hills. It runs fine on straight aways but when i start going up hills the rpms drop and jump back up and keep doing that and the cars starts to buck. I dont know what it could be i have asked my friends and they arent to sure either. I comute 8 hours round trip every weekend from college to come home so i really dont want to get stuck. Does anyone have any ideas what it could be?
Mar 14, 2010 at 3:23 AM
SATURNTECH9
  • 30,869 POSTS
If u put the a/c on when ur on level ground will it buck then?I would pull the spark plug wires off ur coil towers see if there is white powder on them if there is u will have to replace ur spark plug wires.also with white powder on the coil towers it will have to be cleaned or the coil replaced.let me know what u find.
Mar 14, 2010 at 7:16 AM
SHOALIN08
i pulled the wires off and there is no white powder on them. Also if i turn the A/c on i doenst buck on straightaways. Idk what it could be.
Mar 15, 2010 at 9:02 AM
SATURNTECH9
  • 30,869 POSTS
Usually if ur cutting out while driving under a load with a/c on or climbing hills it's usually bad plugs or wires.check the other end of ur wires where ur wires go onto to ur spark plugs look for black powder in the wire boots.also look at ur plugs for being worn out on the tip or black powder.do u have any trouble codes go to a auto parts store like autozone and if u do then let me know what the code numbers are.let me know what u find.
Mar 15, 2010 at 5:02 PM
