1997 Saturn SL1 Brake Pressure
TANZISSATURN
Brakes problem
1997 Saturn SL1 4 cyl Front Wheel Drive Automatic alot miles
Theres a fluid leaking from somewhere just above my tire that I noticed after my brake pedal just went all the way to the floor with little to no resistance... Is there air in my line that caused the leak or is there maybe a break in the line?
Apr 5, 2010 at 5:43 AM
SATURNTECH9
  • 30,869 POSTS
Air in the lines doesn't cause leaks.if u have fluid leaking then u have a leak.is it front or back?check ur wheel cyclinders also.let me know what u find.
Apr 5, 2010 at 6:26 AM
