HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Saturn
SL1
Climate Control
Heater
Heater Core
1997 Saturn SL1
TONY PREUHS
MEMBER
1997 SATURN SL1
1997 Saturn SL1
What is the average or "flat rate" time to replace a heater core in a 97 Saturn SL1?
Sunday, March 29th, 2009 AT 12:29 PM
BLUELIGHTNIN6
MECHANIC
Approx. 2 hours.. An estimate is below..
Thanks for using 2CarPros.com!
Monday, March 30th, 2009 AT 12:45 AM
Please
login
or
register
to post a reply.
Related Heater Heater Core Content
Changed The Heater Core Now Car Running Hot
Two Days Ago Water Was Leaking On Passager Side Of Car So I Changed The Heater Core Now My Car Is Running Hot When I Come To A Light. When I...
Asked by
dflores12
2000
SATURN SL1
GUIDE
Heater Core Replacement
A heater core is positioned inside the car and is part of the HVAC system. Hot engine coolant is run through the core which air is blown through via the blower motor which ...
1995 Saturn Sl1 Heater Core
Heater Problem 1995 Saturn Sl1 4 Cyl Four Wheel Drive Automatic How Do You Repair A Heater Core
Asked by
lequan815
1995
SATURN SL1
1998 Saturn Sl1 Bypass Heater Core
Heater Problem 1998 Saturn Sl1 4 Cyl Automatic 109000 Miles How Do You Bypass Heater Core?
Asked by
bonitab
1 ANSWER
1998
SATURN SL1
Is My Heater Core Needing Replaced?
I Can Smell Antifreeze When I Have The Heater On. Please Advise
Asked by
Cheripayne
2002
SATURN SL1
Heater Blows Cold Air Had System Flushed Hose That...
Heater Blows Cold Air Had System Flushed Hose That Goes To Heater Core Hot Gets Cold Towards Heater Core
Asked by
Anonymous
1999
SATURN SL1
VIEW MORE
Heater Hose Replacement Chevrolet Camaro
Coolant Leak Symptoms
