1996 Saturn SL1 my engine has failed due to a lack of oil.
1996 SATURN SL1
200,000 MILES • 6 CYL • 2WD • MANUAL
YTIZZO24
There was a loud knocking noise before the engine failed. Due to my engine failing because of a lack of oil, Is it mandatory that I replace the whole engine or can i repair the part (s) thats damaged. I bought the car for $500 bucks so replacing the engine is out of the question for me.
Jan 7, 2010 at 10:13 AM
PEAR69
  • 1,482 POSTS
When an engine fails due to no oil in it, you must tear completely down to determine the extent of the damage..Then you must rebuild everything -- this involves machine work and percision measuring of all clearances -- even then it is not guaranteed that the engine is rebuildable. That is why it is best to replace the entire engine with a new one - or a remanufactured one. Rebuilding your existing engine (now-a-days) is usually not cost effective..
BTW - The parts that are damaged are probably the rods - pistons - crankshaft - camshaft - and the block. Even if the block is good (which I doubt) those parts add up to a replacement engine..
Jan 7, 2010 at 5:36 PM
