1996 Saturn SL1 leaking transmission fluid
GARVIN WILLIAMS
Transmission problem
1996 Saturn SL1 4 cyl Front Wheel Drive
the car is leaking fluid rapidly from the front drivside of the car. It comes out faster when i put the car in reverse.
Mar 24, 2010 at 4:54 AM
SATURNTECH9
  • 30,869 POSTS
It leaks faster in reverse because reverse uses full line pressure.so where's it leaking at?around the filter see if that's loose.let me know.
Mar 24, 2010 at 5:23 AM
GARVIN WILLIAMS
[quote:a35dadd0c0="saturntech9"]It leaks faster in reverse because reverse uses full line pressure.so where's it leaking at?around the filter see if that's loose.let me know.[/quote:a35dadd0c0]
yes its near the filter, should i replace it?
Mar 24, 2010 at 5:27 AM
SATURNTECH9
  • 30,869 POSTS
If it's near the filter here's what u do take off the intake tube off the throttle body take it off the car then unbolt the air box that holds the air filter move it aside don't unplug the sensor in there or u will set some codes.then see if the filter is loose or the gasket on it is torn.let me know what u find.
Mar 24, 2010 at 5:53 AM
GARVIN WILLIAMS
[quote:f316bc131e="saturntech9"]If it's near the filter here's what u do take off the intake tube off the throttle body take it off the car then unbolt the air box that holds the air filter move it aside don't unplug the sensor in there or u will set some codes.then see if the filter is loose or the gasket on it is torn.let me know what u find.[/quote:f316bc131e]
Ok louie, I will donate something , I will try what you said and get back to you
Mar 24, 2010 at 7:03 AM
