1996 Saturn SL1 head gasket repair
BOOKHOLDER
  • 5 POSTS
Engine Mechanical problem
1996 Saturn SL1 4 cyl Front Wheel Drive Manual
I tore the engine down, replaced the head gasket and put the head back on. After replacing the timing chain the crankshaft and camshft pulleys would not turn. I removed the head again, both the crankshaft and camshaft turned freely. Replaced the head and neither would turn. Any ideas?
Jul 6, 2010 at 1:28 PM
SATURNTECH9
  • 30,869 POSTS
Did you have all the timing marks lined up when you put the chain on?
Jul 6, 2010 at 5:34 PM
