1996 Saturn SL1 Fuse keeps blowing
FRUSTRATEDWITHCARS
1996 Saturn SL1 Automatic
We have a 1996 Saturn SL1 that keeps blowing the injector fuse. We have replaced the map sensor, replaced the fuel rail and all of the injectors. After replacing the fuse it may run for a little while, but won't stay idle. Dies out everytime you stop. Then the fuse will blow again. HELP! :)
Mar 21, 2010 at 10:35 AM
SATURNTECH9
  • 30,869 POSTS
If ur injector fuse keeps blowing then I would look at wires that run Along the rail they short to the metal.u will see bare wire exposed.what codes do u have?
Mar 21, 2010 at 11:19 AM
