1996 Saturn SL1 Fan does not come on
1996 SATURN SL1
196,000 MILES • 4 CYL • FWD • AUTOMATIC
LAUREN1989M
Where is the Connecting Relay Location for A/C and Fan
Jun 30, 2009 at 7:47 PM
CLOCKWISEMONEY
  • 7 POSTS
Hi
So I have a suggestion for you. Honestly, if you want a correct fix to this I cant help you. I am unfamiliar with the relay system in saturns.
I can however help you bypass the fan relay and run the fan directly off a switch you can by at any car parts store. I own a 95 sl1 and did the same thing, I just turn it on when the car heats up past halfway and then shut it off. It certainly works.
If you are even slightly mechanically adept you should be able to do this with little work. Let me know if you are interested and ill walk you through it.
Jun 30, 2009 at 8:15 PM
