1996 Saturn SL1 Car horn.
DANCINROUNDU818
1996 Saturn SL1 4 cyl Automatic
The horn on my saturn is broken. The fuses and everything are good because I checked them. I got a horn from a grand am and there are only 2 wires and mine has 3 wires.... 2 black and one orange. How do I connect the horn?
Jan 22, 2010 at 7:29 AM
SATURNTECH9
  • 30,869 POSTS
lets check and make sure ur switch is good and that u have power to the horn before we go replacing the horn.just because u have a good fuse doesnt mean everything else is good.ok ur a terminal on the connector which is a orange wire should be a constant power.next ur b terminal is ur ground trigger from ur switch that should have ground only when u press the horn button.last ur c terminal is a constant ground.if all that checks out good u have a bad horn.if u have a bad horn u should just get the right horn for it instead of trying to make one fit from another car.alot less hassle u could even find on at a junk yard if u dont have alot of money.let me know what u find.
Jan 22, 2010 at 2:34 PM
