1996 Saturn SL1 1996 Saturn sl1 horn
176,000 MILES • 4 CYL • 2WD • AUTOMATIC
STAUSHA
  • 6 POSTS
Horn doesn't work tried changing fuses and still doesnt work.. What could it be?
Oct 8, 2010 at 9:56 AM
SATURNTECH9
  • 30,869 POSTS
You could have bad wiring horn switch or horn.Do you have a test light?
Oct 8, 2010 at 10:24 AM
STAUSHA
  • 6 POSTS
Yes i tested the fuses and they work ( if thats what your tlkn bout).
Oct 8, 2010 at 10:27 AM
SATURNTECH9
  • 30,869 POSTS
No i was thinking about you removing the driver side head light assembly and seeing if the orange wire terminal A to the horn wire has power the black wire terminal C has a constant ground and the black wire terminal B has a ground when pressing the horn button.
Oct 8, 2010 at 10:43 AM
